I learned today how well my 2.25 petrol will run on 3 cylinders! Pulling the plug wires, #3 popped right off the distributor after I pulled the other end off and was moving it out of my way. At least the rubber boot popped off - the metal connector was still in the distributor. These are some after market wires the PO put in. It looks to me like the connector was never even crimped down onto the wire!
I pulled the plugs - sure enough #3 was dripping wet with gas. I don't think it was ever firing. I 'borrowed' the wires from the 109 project engine. One of the other after market wires came apart taking it off the dizzy as well.
Other than a rough idle for the first 5 mins or so on a cold start, I've not noticed any running problems. I had been thinking maybe dirty/misadjusted carb issues. now that it has 4 good wires, even that has gone away. Just to see, I tried pulling the #3 wire off; my roughness came back and I lost about 100 RPMs - put it back and idle improved again.
I'm amazed how well it ran on 3 cylinders! I'm hoping for 25% better MPG now
I'm not sure what I learned except to not take things for granted.
Oh yeah - the plugs are Bosch - they have two little ears instead of the normal L-shaped electrode. I'm replacing them cuz I have no idea if they are correct or how to gap them.
