DASH PANEL
  • swanny681
    • Aug 2009
    • 7
    DASH PANEL
    Anyone have any pictures of a good series IIA dash panel both front and back and what are the markings on the main light swict
    h= headlights ?
    s= running lights?
    a= ampgauge?
    Thanks Swanny
  • Nium
    • Aug 2009
    • 400
    Dash
    You'll have to decide if this is a good dash, but here's a pic of the one in my rig.
    Switches from left to right
    Heater, Wiper, Side/Head, Panel Lts/Interieor Lts
    Sorry but I'm not really inclined to pull it out to photo the back. What were you wanting to see?
    Walker
    1968 Series IIA-"Ronnie"
    88" SW, 2.25L Petrol, LHD
    • HybridIIA
      • 98
      Sounds like you have an early IIA dash? My light switch says H/S/Off... of which you have the H and S identified correctly. Below is a photo of my early IIA dash, but it is not quite stock. I swapped in a different speedo, removed the amp gauge & moved the main beam indicator light in its place, and added a temp gauge to where the main beam was.
      h= headlights ?
      s= running lights?
      a= ampgauge?
      Thanks Swanny
      '62 109 - coil sprung
      '64 88 - coil sprung
      • superstator
        • Aug 2008
        • 298
        Mine is exactly like Nium's, except the heater switch and choke are reversed (and my choke has been repurposed as a diesel pump cut-off). I thought the textured black panels where a NADA 109 thing only?
        • Nium
          • Aug 2009
          • 400
          superstator,
          Truth be told I'm not 100% sure that my dash is stock. I guess I should of put in a disclaimer or somethin. The history I know of Ronnie is that the first owner use to drive 'im back and forth from Maine to Key West. The owner's, my family got him from, found him with a palm tree growing through the engine bay in Key West. Rescued and restored him to running condition. That was sometime in the early '80s I have bins of paper work somewhere. My Dad bought him from them and I got Ronnie from him, years ago. The dash very well could be from a 109.
          Kinda an interesting side note. My dad told me that the people he got Ronnie from worked with Mel Fischer when he found the Atocha. They'd load up the back of Ronnie with silver bars and haul them from the docks to the warehouse where they'd clean up all the treasure. Not saying I know it's fact just what me dad told me.
          What did you mean by "textured black panel"? The dash is just smooth painted metal.
          Walker
          • HybridIIA
            • 98
            You are correct, only NADA 109's got the textured black dash panel. However, later IIA's got black (non-textured) dash panels regardless of the body color... which is what I think Nium's is.
            • superstator
              • Aug 2008
              • 298
              Originally posted by Nium
              superstator,
              Ah - I saw the year and it looked so much like mine that I wondered if the factory might have thrown in a NADA panel on an 88 just to keep us on our toes.
              • Andrew IIA
                • Feb 2008
                • 327
                I just happen to have a pic of the back of my early IIA dash panel handy. I had it open to track down a charging system problem; the yellow wire on the lower left is a 'jumper' i put on the charge light to help diagnosis.
                My light light switch has 'Off' 'S' (for Side) and 'H' (for Head).
                Best regards, Andrew
                '63 SIIA 88" SW
                Andrew
                '63 SIIA 88" SW
