Clutch Pedal Box
  • JackIIA
    • Dec 2008
    • 498
    Clutch Pedal Box
    Stumped by the removal process for the clutch pedal shaft of my 88. The manual simply states "remove locating pin from shaft and withdraw shaft". (ha!). It won't budge despite heat, penatrating oil, and forceful use of both a hardened punch pin and a vice.
    So first question, is the best approach indeed to put alot of force on one side of the shaft (as circled in the photos) and drive it through to the other side? I'm assuming that this shaft sits inside 2 bushes within the pedal box, and that there is nothing physically preventing one from sending it all the way through, pushing it from the side with the pin, toward the side with the oil plug.
    Before I go gorrilla on this, is there a better, kinder approach? Hate to risk trashing the assembly. Shaft and bushings I'm talking about are circled in the last shot. Thanks!
    1970 88 IIA
  • Nium
    • Aug 2009
    • 400
    Locating pin
    Did you remove the locating pin (part # 24 in the diagram clutch-pedal-schematic)? The locating pin should be a small rolled pin (approx. 1/8" in diameter) that you would use a thin drift punch to drive out. The locating pin is not the pedal trunnion (circled part # 23 in diagram) nor the pedal bush (part # 20 I think that's the part # it's kinda blurry). The locating pin is on the outside of the bracket. There should be a small hole the locating pin passes thru on the outside of the bracket shown in pic clutch_pedal_2. The locating pin hole is vertical not horizontal. The locating pin passes thru the bracket and then thru the pedal shaft thus securing the pedal shaft to the bracket.
    If you go gorilla on the pedal shaft and try to drive it out before you remove the locating pin you'll probably need a whole new assembly.
    Hope that helps,
    Cheers
    Walker
    1968 Series IIA-"Ronnie"
    88" SW, 2.25L Petrol, LHD
    • JackIIA
      • Dec 2008
      • 498
      Thanks Walker. Yes, I did remove that pin before trying to force the shaft out. I would guess that it's just rust-welded in place given it's probably never been disturbed in 39 years. (What throws me off is that the shaft is inside brass bushings, so I wouldn't expect it to seize up at all).
      I'll just keep whacking away at it I guess. The manual doesn't specify which side to tap from, but I'll assume one would be applying force from the side of shaft where the pin resides?
      1970 88 IIA
      • Nium
        • Aug 2009
        • 400
        OK. It's been awhile since I've removed pedal shafts from the brackets too. Looking in the manual for the brake pedal (I know your working on the clutch pedal but their basically the same) it says to remove the locating pin from the pedal shaft. I went and looked at my pedals and from the toe box side I couldn't see a pin on the pedal shaft maybe you can see one with the cover plate off the bracket. Plus if you look at the diagram you can see a set of holes on the pedal shaft that looks like a pin would go thru.
        If there isn't one I'd guess you should try and drive from the side opposite the locating pin not the side of the locating pin since the pin would be probably be on the side where shaft would come out of.
        Sorry if I'm not much help. I agree with you that it shouldn't be rusted in though. Just one of them head scratchers.
        Cheers!
        Walker
        • kevkon
          • Aug 2009
          • 364
          When you move the pedal, what moves, the shaft, the shaft and the bushing(s) or nothing?
          Sometimes after much use the shaft can wear to such a degree that it gets a shoulder on it.
          94 D-90 tdi
          72 Series III
          • JackIIA
            • Dec 2008
            • 498
            Thanks - no joy.
            Nium - thanks for taking a look at your brake box for me. Kevkon, the pedal and bushings move as one unit, which looks OK. Hadn't thought of your point on a shoulder forming. I think I'm going to take this to a machinist and have the shaft drilled out. The box has a very slight warping around the shaft housing, which means more than enough muscle been applied already.
            It's always surprising what causes delays in a rebuild! Thanks again.
            1970 88 IIA
            • Nium
              • Aug 2009
              • 400
              Did you get it out?
              Walker
              • jb_
                • Nov 2008
                • 47
                I have the same problem with the clutch pedal on my '74 109 RHD.
                I've removed the pin at the opposite end of the shaft to the oil bolt hole.
                In my case the shaft is locked to the clutch pedal box. I can only just move the pedal now that it has frozen up probably after lack of use. So I really want to get it apart and clean up the bits.
                I haven't hit it yet. But I feel a lot like doing that. LOL.
                Does heat usually free up rusty surfaces, or should I soak it in something?
                '74 Series III 109" RHD
                The Chaffcutter (choof choof phut phut)
                • Bertha
                  • Nov 2007
                  • 384
                  More times than not is is going to require a lot of heat(something more than a propane torch) and a bit of force, but be warned that with too much pounding, you will distort the tube that the pin goes through, that is welded onto the box. Penetrating oil won't be of much use. So try and heat it until it is red and give a few moderate hits. If it doesn't move, re-heat again-don't keep pounding or you will distort it, especially when the metal is at such a high temp. As a point of reference, I have spent as much as an hour screwing around with some really bad ones, so be prepared to heat and re-heat a few times.
                  One other thing-you will need to apply heat evenly across the entire shaft, not just the end.
                  1971 88 (restored and as new)
                  1967 88 (the next project)
                  • jb_
                    • Nov 2008
                    • 47
                    Thanks for the reply.
                    Hmmm. The only way I have to heat it is with a propane torch. And even then I'm likely to heat up the entire pedal box too.
                    • jb_
                      • Nov 2008
                      • 47
                      Now that I look at it again after leaving WD40 soaking in via the oil hole over night, I can move the pedal freely this morning. I think that's probably the hint to leave the shaft where it is and just keep the pedal/shaft lubricated in future.
                      Time to just put it all back together.
                      • JackIIA
                        • Dec 2008
                        • 498
                        yeah, leave it be
                        Sorry Nium - didn't see your post on Oct 4th.
                        Jb - I agree leave it alone. Bertha's right, propane won't do much. I used Mapp gas repeatedly, got it glowing red hot, hit it with penetrating oil both before heating (and after cooling, to prevent warpage) and got absolutely no movement of the pin, despite some heavy blows with a punch. But I did manage to slightly distort the box...so I have that going for me.
                        Brought it to a professional rover mechanic who pointed out my idiocy and I agreed (I usually don't media blast and repaint without full dissembly...just seems wrong), but this was the best course of action with this thing.
                        1970 88 IIA
                        • jb_
                          • Nov 2008
                          • 47
                          Mine is all back together now and I have a lovely clutch feel, even if I do say so myself. Chuckle.
                          I even put some new springs on the gear lever thingy. So the gear stick feels good too, in a land rover kind of way.
                          I had a good day right up to the point where I tried to get the bolts off the gearbox that cover the selector tension springs. I don't seem to have the right spanner sizes for those.
                          • Bertha
                            • Nov 2007
                            • 384
                            You will need a Whitworth tool set for the trans.
