LizardSkin or other Heat Shield
  • brunomacarto
    • Sep 2009
    • 7
    Greetings to all,
    I have my '64 Ser. IIA down to the bulkhead, and had a flashback of the heat/noise transfer through the bulkhead.
    I found 'LizardSkin' on Eastwood's site, but has anyone used this, or another product to reduce heat/noise transfer through the bulkheads and floorboards?
    -Brian
  • xsbowes
    • 258
    Wonder if it resists chipping from rocks? Sparticles? No wonder the spartans were so angry.
    Stacy
    Motta S.A. Italy
    • east high
      • Jan 2008
      • 337
      Eastwood needs a proofreader...
      '67 sIIa 88
      • frans
        • Mar 2009
        • 29
        Kind of a gimmick. Works sorta but really no joy.
        I tried a similar product, http://www.metalshield.com/buyrustproofing.html Which is the same idea except that it has a rust inhibitor.
        20-25 degree temp. drop seems about right. Translates into too much trouble for such a little gain. My series was still way too hot on the floorboards.
        Ended up getting Sound proofing material, it works much better.
        • thixon
          • 909
          Brian,
          X2 with Frans. I used the stick on stuff in my first series and got great results. IIRC I went all over the bulkhead, flloor, and seat box.
          Good luck.
          Travis
          '66 IIa 88
          • Bertha
            • Nov 2007
            • 384
            I applied lizard skin to my current 88 restoration. It is on the lower part of the bulkhead and on the underside of the rear body. I applied both the noise component and the sound component. I have also used some heavy duty sound deadening pads throughout the truck, so it may be hard to say exactly how much affect the Lizard skin product actually has. It seems very durable and worked really well as a seam sealer so far, however the truck is not "officially" on the road yet, so I can not attest to its sound deadening capabilities or its heat resistance as they claim. I will update everyone once I put the hardtop on and go for a long ride. I will say it wasnt cheap by the time I bought the applicator and the 2 products.
            1971 88 (restored and as new)
            1967 88 (the next project)
            • Bertha
              • Nov 2007
              • 384
              Definitely should resist rocks based on the way it looks so far.
              • thixon
                • 909
                Hey Bertha,
                Did you top coat it with paint, or did you just leave it alone?
                Travis
                '66 IIa 88
                • Bertha
                  • Nov 2007
                  • 384
                  Originally posted by thixon
                  Hey Bertha,
                  Yes. It top coated very well. I ran out of picture post space on the board, however if you are interested I could email you some close up pics-just PM me if interested.
                  • txeagle
                    • 16
                    Go out to the hotrodders.com forum and search for lizardskin. There are a couple of threads dealing with lizardskin and how to make an much less expensive alternative.
                    Ben
                    Too many projects, not enough time and/or $$
                    1966 S2a 88, 1973 Vette
                    • 4flattires
                      • Aug 2007
                      • 424
                      Eastwood grammar is one thing...
                      ...but math is another.
                      "One 2 gallon container covers..." They sell it in the 1 gallon pail.
                      Whoops!
                      J
                      64 SIIa 109 all stock
                      69 SIIa 88 all stock
                      Old tractors
                      New Harleys
                      Old trucks
                      • txeagle
                        • 16
                        OK, here's the thread on hotrodders about making your own version of lizard skin...
                        Since RB's Obsolete had the Cool-Car ceramic insulation on backorder and did not inform me after 3 weeks of waiting on it I have done some research. Seems all the high priced ceramic paint on insulating materials aka Lizard Skin, Cool-Car and such are a simple mixture of an exterior latex paint...
                        Enjoy the reading.....
                        Ben
                        • frans
                          • Mar 2009
                          • 29
                          In the quest for a quiet/cool series...
                          First I used the coating, which didn't seem to do anything really other than seal up the odd holes here and there.
                          Then I applied engine compartment material which made a big difference, but I still got alot of heat through the floor boards.
                          So now I am thinking of installing a heat shield betwix the exhaust pipes and the floor boards.
                          My 109 has a chevy conversion and the two pipes generate alot of heat. The other day during a warm afternoon my IF heat gun/measuring device showed a temp of 150F on the floor board!
                          With the pipes less than 2 inches from the floor boards I am thinking that a heat shield is really the only way to funnel the heat away.
                          I will use a thin sheet of steel or tin, curve it around the pipe between the pipe and the floor boards, and mount it so it stands away from both by just a bit.
                          • Tim Smith
                            • 1504
                            What about using exhaust insulating wrap? I've been thinking about it but it's low on the list.
