Heater blower
  • swanny681
    • Aug 2009
    • 7
    Heater blower
    I am looking to find out where the fresh air to my heater is brought in at on this IIA, I think it is near the bug screen on the pass. side but have found no pictures or drawings or part numbers to that effectany pictures would be great.
    Swanny
  • Andrew IIA
    • Feb 2008
    • 327
    Swanny, what year is your Series ?
    The most common location for the fresh air intake is on the right side above and abaft the wheel well, but some years had it low in the breakfast or in the inner wing panel near the breakfast.
    You can see the intake in the common location on my truck here:
    Best regards, Andrew
    '63 SIIA 88" SW
    Andrew
    '63 SIIA 88" SW
    • thixon
      • 909
      If yours is set up for the breakfast configuration, the duct will run down the bulkhead, and run under the battery tray to the front of the breakfast. There will be a bracket fastened to the pass side opening on the breakfast for the duct to connect to.
      I'm not using this config on the truck I'm building, but it originally came that way. I still have the bracket if you need one.
      Let me know.
      BYW, Nice truck Andrew!
      Travis
      '66 IIa 88
      • swanny681
        • Aug 2009
        • 7
        intake location
        there are two holes in the front grille panel area one one the drivers and one one the pass. side with a screen in it so I will look further into routing it there and what it needs?
        Swanny
