I've got a new sound to diagnose. I would describe from the driver's seat as chugging when driving at speed. Clearly tied to engine speed and gets louder with increasing RPM. Throttle position has no effect on volume or frequency. Under the hood if you rev the engine it starts around 2000 RPMs and is clearly coming from the top-front of the engine in the vicinity of the water pump.
I've never had a water pump die so I'm not sure what they sound like. I've also had issues with overheating under extreme loads offroad but it is generally well behaved. The rad and thermostat are new and both hoses on the rad are warm when running. Perhaps it is a low flow problem due to a dying water pump. Maybe I'm being optimistic that I might kill two problems with one solution.
Any thoughts?
Any thoughts?
