I did a compression test on my engine (2.25L with 7:1 head) this evening and found the following:
#1 107psi
#2 60psi
#3 80psi
#4 105psi
This strikes me as #2 and #3 are communicating somehow. Wet compression test gave similar, if not slightly improved results. What would you folks suggest to do next? Remove the head and check the condition of the valves and head gasket? I suspect the gasket is blown between #3 and #4.
#1 107psi
#2 60psi
#3 80psi
#4 105psi
