Have a leaking clutch master( wet spot on floor boards) any tricks to changing these out. will they slowly leak for a while?? the leak just started and not much is comming out just wet. thanks greg
changing the clutch master any tricks? 109 2a
I drove my 88 IIA for about 18 months with a leaky clutch MC, but you are just delaying the inevitable. Also, the fluid will eat away any paint that it comes in contact with as well as rubber floor mats. I replaced mine without taking the drivers wing off, but if I had to do it again I would take the time to take that off first - unless you are a trained contortionist.
Jack
