Rover 67,
Look in the thread "Clutch Pedal Box" posted by JackIIA...
there is a schematic of the Clutch pedal assembly and two pictures of a removed clutch pedal box. You are going to want to lubricate part #22 (shaft for pedal) and part #23 (trunnion for pedal) in the schematic diagram. There is a little bolt in one end of part #22 (shaft for pedal) that you can remove to fill with oil that will lubricate the shaft for pedal, but that it is fairly impossible to fill without removing the pedal box from the toebox first. Try spraying with WD-40 or white lithium grease and working it the lube in by pumping the pedal.
