Recently developed a decent leak from the front output shaft. Reading thru the green bible they show replacing the seal with the transfer case out. Can one replace the oil seal with the transfer case in place?
front output shaft leak
That's an easy one. The seal sits in its own housing on the end of the front transfer case. You can take the housing off, install the seal on the bench and then remount it. -
NAPA will be able to order it. If you want to make life simple pull it off, measure the output flange seal land, the housing ID and the seal thickness. With that info you can go to the SFK website and cross reference it yourself to the Chicago Rawhide part #.A double lip seal is a good idea in this location.Comment
thanks, actually just got off another LR site with a great cross-reference of common seals, bearings, ect. it's Chicago Rawhide # CR16254 or Federa Mogul 450194. Gotta love the internet!04 Disco, Gone-Disco died & so did mine
'72 S3 88 - Leakey & SqueakyComment
or...or, you could look on Teri Ann's site.NAPA will be able to order it. If you want to make life simple pull it off, measure the output flange seal land, the housing ID and the seal thickness. With that info you can go to the SFK website and cross reference it yourself to the Chicago Rawhide part #.A double lip seal is a good idea in this location.
I'll save you some time here. I just went through the same process--I botched up my rear output seal replacement job last week (same seal p/n as front output) and had to get another seal. I called my local NAPA, who could get the part in 3 or 4 days. It cost $15.69 plus shipping (plus tax if you live in a sales tax state).
UPS just delivered a genuine seal from Rovers North a half hour ago. I ordered it yesterday and it cost me $2.48 + shipping. Crazy, eh?--Mark
