88 Rear Cross member Question ?
  • TJR
    • 279
    What are the 3 pads on the bottom of the rear most cross member used for?
    My Galv chassis and my original chassis have them, but I don't recall anything mounted to them?
    Thanks.. Talbot
  • Leslie
    • 613
    Some of the accessories used them to mount to the back of the vehicle (things driven off of the rear PTO). Look at old pictures of Rovers being used as farm equipment, etc., you can see things bolted up to the underside of the crossmember by those....
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    • Bertha
      • Nov 2007
      • 384
      If they are the 3 squares with holes in them, they are for the rear foot step. The holes should be threaded(however you will probably need to run a tap through them)
      1971 88 (restored and as new)
      1967 88 (the next project)
      • TJR
        • 279
        Yes the three square blocks. I've never had the fixed rear foot step assuming that is what you mean.. . But I do have a folding one to rebuild ..Thanks to all for the info..
        • leafsprung
          • 1008
          there are several accessories that use those holes
          • TJR
            • 279
            The 3 blocks are tapped I assume. Mine are all filled w/ zinc.
            Does anyone know what the tapped hole size is? 1/4-28? 5/16 -24? or do I need to drill and tap to my own size?
            ...Thanks..
