The drive axle hub flange bolts on my SerIII 88 are 3/8- 20 BSF thread , Not 3/8-24 UNF thread. With the Warn hubs, the supplied hex head bolts are tough to tighten and remove.
the 3/8-20 tapped holes prevent me from replacing the (6 per side) 3" long hex head bolts with an easier to install socket head cap screw.
As an option has anyone drilled out the 3/8-20 tapped holes and insert a UNF helicoil to change to a 3/8-24 UNF tapped hole? Jusst an idea right now.
otherwise , does anyone know were I can purchase 3/8-20 BSF socket head cap screw x 3" long??
Thanks..Talbot
Thanks..Talbot
