Auxiliary fuel valve lever
  • bronsonarlo
    • Mar 2008
    • 29
    I found one of these levers for cheap and decided to do a dual tank setup. Does anyone have a picture of where they are mounted or at least a recommended location?
  • superpowerdave
    • Aug 2009
    • 32
    The one on our 109 is mounted on the vertical face of the passenger footwell near the tunnel. I can snap a photo later if you like. If I had done the install I would have found another location though. It's tucked up nice and high but difficult to get to from the driver seat, easy access for small children to mess with, etc.
    1964 SIIA 109 | 1973 SIII 88 | 1995 RRC | 2000 DII | 2000 P38
    • scott
      • 1226
      i don't have the fancy smancy rover valve, just a brass one you can pick up from most any marine shop. i mounted it on the back of the blank plate that covers the hole in the seat box that the rhd e-brake lever would otherwise be. the handle is in the cab, the valve in the seat box. looks clean and i can easily reach it will driving which is good cuz i got no fuel gauge.
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
