Nick,
If you're gonna buy paint, and put in the time, then you really need to pay attention to the prep side of things. 95% of the job is in the prep. If you don't do it right, you won't be happy with it. Sounds like Bertha has you covered, so I won't preach.
The only thing I'll add is this. If you go with an epoxy primer (which is a great choice on bare aluminum), and a 2K paint then you need to consider buying a respirator, and covering up when you mix and spray. Someone above mentioned isocyanates. Read up on them. Anyone telling you that anything less than positive pressure air fed respirator will work doesn't know what they're talking about. You can buy a hobby air for $500 or so nowadays.
Unless you just want to do it yourself, you might consider a local paint shop. It would cheaper for you in the end.
. Don't remember which paint it was like I said it was over ten years ago.
