I read quite a bit here and appreciate all the sage advice I have picked up to help with refurbishing my 1982 SIII 109.
This week I am working on the front axle. The railco bushings showed an egg shape in the leather? and the upper pins had an obvious shoulder just below the machined one worn in to them. I replaced the railco bushings, upper pins. One of the lower bearings was bad and I replaced it as well. Upon putting the swivel balls back together the fit of the upper pins in the railco bushings was very tight requiring help from my mallet.
The turning tension with 0.015" of shims was about 25#, not 12-16# on both swivel balls. I pulled out the upper pins, and measured the distance from the top of the wafer to the top of the swivel ball using the rod end of my caliper, it measured almost 0.1" longer than the upper pin length.
Only having so many shims...
The turning tension with 0.065" of shims in is still about 25#, not 12-16# on both swivel balls. So adding shims doesn't appear to be making a difference. I am wondering if I ruined the bushings by tapping them in with my mallet rather than pressing them in? Should I run them a bit and recheck?
Another question, is there another purpose to the tension in the upper pins then damping the steering?
Thanks for any help. I appreciate all comments.
