before I put my rover on the road I waxoyled the new frame. I am working on doing a little cleaning of the truck. One thing with the waxoyl is that it is hard to clean grit off of. I would like to clean it up and then recoat. What is the best way to clean sand / grit from waxoyl traeted frame>
waxoyl
The best way would be to let someone else do it!
Actually I have been removing waxoyl from my frame so I know something about it. I think your best bet is to live with the grit that can't simply be washed off since if you try to remove it you will compromise the waxoyl coating.94 D-90 tdi
72 Series III
