Series II trans to Series III swap
  • 1967IPA
    • Sep 2009
    • 30
    Hi all!
    I was wondering - if I plan on going full syncro series III transmission from the series II that is currently installed, what mods am I going to need to plan on?
    Thanks!
    Michael
    SoCal, USA
    1973 Series III 88"
    2008 LR3 HSE
    1995 RRC - Cream Puff - Sold
    1960 Series II 109 SW "Pequod" - Sold
    1967 109 NADA SW #360 - Sold
    1962 IIA SWB - Sold
    1992 RRC LSE - Sold
    1973 Series III RHD ROW - Sold
  • Nium
    • Aug 2009
    • 400
    I haven't done it but from what I can ascertain it is a straight swap. Take out the old gearbox mate the new (Series III) to the transfer box and bolt it all back up to the engine. Probably should replace all clutch components (clutch disk, pressure plate, throw out bearing, bush for primary pinion in flywheel, and rear main seal on engine) while you are in there, for the swap you shouldn't have to replace clutch components but may as well while you are in there.
    As reference check out
    Cheers!
    Walker
    1968 Series IIA-"Ronnie"
    88" SW, 2.25L Petrol, LHD
    • Les Parker
      • May 2006
      • 2020
      The swap for a IIa (B suffix onwards) and Series III you'll need to swap the bell housings over, as the clutch realease is very different twixt the 2.
      Make sure you stand the geearbox on its end, ie transfer box, so you are not fighting gravity with the main and layshafts.
      You probably will need a new gasket # RNB393.
      Les Parker
      • Bertha
        • Nov 2007
        • 384
        You will also need to re route the clutch line as the s3 slave cyl is located on the left side of the truck, unlike the s2 slave which is located on the right side.
        1971 88 (restored and as new)
        1967 88 (the next project)
        • 1967IPA
          • Sep 2009
          • 30
          no notching of frame and/or trans tunnel to accomodate the switching sides of the slave cyl?
          Michael
          SoCal, USA
          1973 Series III 88"
          2008 LR3 HSE
          1962 IIA SWB - Sold
          1992 RRC LSE - Sold
          • Bertha
            • Nov 2007
            • 384
            The new galv frames are made to s3 spec and should not require any modification, hoever if you are running with an original early frame there will be a small traingular brace welded to the crossmember in that area that will need to be ground down a little bit. Either way, it is not that hard of a job.
            • ducttape
              • 177
              Chimming in, just to follow this link
              1967 Series IIA 88
              • mongoswede
                • May 2010
                • 757
