I'm re-installing the instruments on my late Series 3 Air Portable. This vehicle should use the same fuel and water temp senders as a civilian S3.
Now, there definitely was NOT a voltage stabilizer installed on this vehicle, and there was no sign whatsoever of there ever being one. The green wire feeding the water temp and fuel gauges comes off of the fuse block and goes directly to the gauges. Is this normal?
All the wiring diagrams I have shows that the green wire should go into the voltage stabilizer, then a light green wire should come out and go to the gauges. I have the stabilizer and was about to modify the wiring when I thought that I better check with the experts.
What should I do?
What should I do?
on what year vehicle you're dealing with and what gauges have been fitted.
Finally, something on my SIII as it should be! WooHoo! Maybe working on the wiring won't be so bad?
