Well,
I pulled apart my bad swivel on saturday. After seeing what was inside, I've decided that (IN MY OPINION) grease is a horible idea for series swivel balls. So, in short, I've changed my mind. No grease for me thanks.
As you can see from the photos, the pitting allowed water in, and it sat for who knows how many decades. Even if you have swivels in great condition, H2O will probably get past them if the truck is dunked. If the swivel is full of grease, then the only way to get the water/mayoniase grease mixture out would be to disassemble, clean, and reasemble. If the swivel is full of 90 wt, all you'd have to do is drain, refill, and you're good. I'm not even mentioning the needle bearings in the shaft u-joint, but i'm sure they'd be trashed.
I did'nt take photos of the rest of the guts, but suffice it to say the railco and lower bearing were all cold welded into place due to the water and rust. It took no less than an hour of beatings with the hammer and heating with the smoke wrence to get the steering arm out of the lower section.
The other side is not as bad, but looks like I'll be assembling parts for a full rebuild on both sides. Oh well.
