Whitworth spanners/wrenches
  • jb_
    • Nov 2008
    • 47
    In the thread on the clutch pedal box I commented on the fact that I didn't have the spanner sizes for the bolts on the series III gearbox that hold the bracket that covers the detent springs.
    So I went to a local auto parts place to ask about prices for Whitworth spanners. The sizes that they mentioned seemed to line up with my A/F set, so now I'm wondering what "Whitworth" actually means. Is it the size of the bolt head, or the threaded shaft?
    The prices that the auto parts place quoted me were frightening. I can't imagine paying more for a set of spanners than my series cost me!
    I'd like some advice from those here in the "know" about what spanners (wrenches) are required to service a 74 series III other than those that are part of a normal metric/AF set.
    '74 Series III 109" RHD
    The Chaffcutter (choof choof phut phut)
  • Nium
    • Aug 2009
    • 400
    Gives a bit of an explanation why you need Whitworth spanners. You could try just to get the wrenches and sockets you need for the job at hand instead of a whole set.
    Walker
    1968 Series IIA-"Ronnie"
    88" SW, 2.25L Petrol, LHD
    • crankin
      • Jul 2008
      • 696
      Your high cost is probably coming from the fact that Whitworth's thread system is no longer around and people are having to special order the wrenches. Also, I see you’re in Oz... here in the states I have seen sets for as low as $50.
      Whitworth fasteners used a 55 degree thread angle. The wrench sizes were marked crazy. Basically, the dimension given on a Whitworth wrench is the diameter of the bolt thread rather than the size of the head. Some Whitworth wrenches even have two marked sizes, because the same head size is used with one coarse thread and a different diameter fine thread.
      British Standard Whitworth (BSW), British Standard Fine (BSF), British Standard Parallel Pipe (BSPP), and British Standard Tapered Pipe (BSTP) are all thread series based on the Whitworth screw thread form.
      Nium sent you a great link.
      Birmabright Brotherhood
      Clint Rankin - 1972 SIII SWB
      • greenmeanie
        • 1358
        As a Scotsman I'm a bit tight with money. I've got away with a set of metric tools for years. I've probably accumulated most of the imperial sizes over time but never bothered with whitworth. Where I come across it I usually remove it and replace with imperial fasteners these days.
        There is the cool factor I suppose but I just can't justify it.
        • jb_
          • Nov 2008
          • 47
          I will be in the US (California) next month. Is there somewhere I can buy them while I'm state-side?
          • Bertha
            • Nov 2007
            • 384
            Here you go:
            1971 88 (restored and as new)
            1967 88 (the next project)
            • kevkon
              • Aug 2009
              • 364
              It would probably make more sense to get a 3/8 " drive Whitworth socket set given the need on a Series truck.
              94 D-90 tdi
              72 Series III
              • brucejohn
                • Jul 2009
                • 215
                I am not going crazy!
                Thank you jb_ for asking this question and Bertha, crankin, greenmeanie, kevkon and Nium for the answers. The history was especially interesting and enlightening.
                Being new to a Series truck I have been very confused at the almost fits on bolt heads with my SAE and Metric selection and my inability to find local sources for bolts I wish to replace. I had assumed that my difficulties were the product of years of rust and corrosion such that the bolt heads aren't what they were when installed. But it has been very confusing and frustrating not to be able to go to Tractor Supply or Lowes to find replacements for bolts going back into tapped parts. Now I know why.
                Thank you, thank you, especially jb_ for asking a great question.
                1982 SIII 109 RHD petrol project.
                • TedW
                  • 887
                  The Series 11A tool kit came with the following Whitworth wrenches...
                  ...according to the Parts Catalogue (and the kit that came with my truck):
                  5/16 x 7/16 Whitworth
                  3/16 x 1/4" Whitworth
                  3/8" Whitworth (single end)
                  What are the chances that these sizes would cover everything you might need to do?
                  • crankin
                    • Jul 2008
                    • 696
                    The chances are pretty darn good. Having taken mine apart, I realized that there are not a whole lot of different sizes of bolts.
                    • Bertha
                      • Nov 2007
                      • 384
                      I agree-the 1/2" drive set is the only size Tripple C sells(which is the one I have) I must admit it is a little annoying to use, but it was the most reasonably priced set I could find and the quality is very good.
                      • gudjeon
                        • 613
                        I usually find them sitting in the wrench bin with a bunch of other stuff at my local pawn/secondhand shop. I found my own set while cleaning out the school shop where I work . It was a Whitty set for an old Boxford Lathe that was removed years ago.
                        • utahseries
                          • Apr 2009
                          • 155
                          I agree, in 95% of my series 1 resto, i've only used those sizes!
                          1956 86" S1
                          1957 88" S1
                          1967 109" SIIA NADA
                          2007 LR3
                          • brucejohn
                            • Jul 2009
                            • 215
                            Our hosts have a whitworth combination spanner/box set, though the website says 3/8" sockets not currently available. A 'whitworth 1/2' google search will bring up 1/2" drive shallow and deep wells as well as spanners and box wrenches.
                            • jb_
                              • Nov 2008
                              • 47
                              Originally posted by Bertha
                              Now _that_ is more like what I'm prepared to pay.
                              Thanks!!!!
                              I ordered a set and hopefully they will be waiting for me when I arrive in sunny Sunnyvale next month.
                              It helps to work for a US company.
