I'll be starting my swivel ball rebuild tonight so I'm sitting here at work obsessing about it not getting anything done. My concern is how to get my Selectro lock out hubs off, from what I've uncovered on searches there are 3 parts to them. An inner splined sleeve held in place on the stub shaft by a castellated nut: an outer sleeve which is bolted to the hub and a cap which can lock the two sleeves together. Sounds like I remover the cap first (I see 3 sets of set screws which I assume holds it to the outer sleeve), unbolt the outer sleeve and then undo the castellated nut and pull the inner sleeve. After that I can use the manual to guide me on the rebuild.
To those who have done this, am I correct in the above plan?
thanks,
thanks,
