I finally got around to getting into my transmission (SIII, B series). It was jumping out of 2nd and the whole drive train felt like it would move (I could feel it in the shift lever) on occasion. After extensive reading here and finding a broken 3/4 synchro spring in the oil when draining the gearbox, I guessed that the main shaft nut was possibly loose. (The transmission was a factory rebuilt unit with less than 10k miles on it, so I didn't think it was completely shot.)
Getting to it took a good long while - yes these trucks are all detachable in some form or fashion, but that does not mean it's not a whole lot of work besides. I found the mainshaft nut was indeed loose and pretty beat up (hammering it in with a screwdriver one supposes). Having a special castleated nut tool from our hosts on hand was the ticket - I got the old one off and replaced the lock washer and nut, tightening it all back up.
Next was the synchro spring...which defeated me, never mind that I had a step-by-step guide of how to insert new ones from others here who are obviously more of a magician than I. I tried and tried but could not get the synchro spring in the 3/4 synchro unit. I dropped it into the bottom of the transmission case at one point which took some doing to get back out. In the end, I simply gave up. I was not going to get that spring in. So I spent another day putting the Rover back together.
Loo and behold, the transmission is great, smooth and tight (well, you know what I mean there). It does not thump about and there is no tendency to jump out of gear.
So - how long can I expect to drive with just 2 out of the 3 synchro springs in place? It drives and shifts as normal, but I expect I'm putting an increased load on the remaining two. Anyone have any experience with this?
. Thought my trip was Kaput!
