I'm working on the passenger side swivell rebuild. New balls, pin, railco, etc.
I can't seem to get the tension right. I started with about 40 thou per the manual, but only got 6 lbs with the old fishing scale. I started subtracting shims to adjust. With no shims at all, the best I register is 9 lbs. Any ideas? I greased everything (bearing, and top pin) with mobil 1 synthetic grease. Should I have not greased the pin?
