2 nights ago, I left work to drive home, and the Rover wouldn't start. I knew the starter was in need of a rebuild, and it was getting worse as the day went by, but it was completely shot. Got it started with the hand crank, and drove home.
I did some reading on the forum, and I removed the starter the next morning. No fuss, and I didn't need to remove the exhaust downpipe like some report needing to do. Bench testing the starter confirms it is toast. and I am taking it for a rebuild today. My question is this. It is an older Lucas starter, with the one positive terminal to be conected, and no ground strap.
I think it would be a good idea to fit a ground strap, am I correct? and if so, where should I attach it to the starter? I was thinking one of the fixing bolts that holds it to the engine, but I wanted some other opinions before I start adding needless wires.
