You can run a rubber hose off the overflow outlet and extend it up a bit, its an old air-cooled VW fix for rough roads. Additional you will probably need to bent the accelarator pump linkage from a gentle bend "(" to almost a "C" to get good response from the rochester. But first address the pressure issue.
Jared
Jared
