Fuel pump replacement
  • McQ01
    • Nov 2009
    • 19
    Sorry if this has been covered before, but.
    Does one need to remove the right side wing to change the fuel pump out ?
  • Jim-ME
    • 1379
    No you don't. It is fairly easy to replace from below.
    Jim
    • McQ01
      • Nov 2009
      • 19
      Glad to hear..the more I look t some of these Rovers, the more I want to rebulid everything!
      Jim, I'm down in Brunswick, ever get down this way?
      • Jim-ME
        • 1379
        You aren't that far away and I'd be happy to lend a hand any time if you need one.
        Jim
        • McQ01
          • Nov 2009
          • 19
          Awesome offer! Im not off from work til after turkey day, and have yet to acquire new clutch master and slave cylinders. I do have a new fuel pump, and rtv form a gasket-tho I will prolly order up a new one when I order the clutch stuff.
          • Jim-ME
            • 1379
            I'd order the gasket if I were you. For some strange reason I haven't had a lot of luck using RTV sealants on the Rover.
            Jim
