I am working on a 1974 109 ex-mod with dual brake master cylinder. So far I have replaced the cylinders at each wheel as well as the brake shoes and had the drums turned. After that I replaced the servo unit and rebuilt the dual master cylinder. I also inspected the brake liines but did not replace them. Everything was put back together and I bleed the system. I went around the truck 3 times at each cylinder and bleed them until there was no air left in the lines. At this point I tried the brake pedal but I got nothing. You can push the pedal down and it will either stay on the floor or come about halfway back up but either way the brakes dont work. With the truck turned off the pedal will go all the way down and come back up but with the truck running and the pedal is pushed down it stays down.
Does anyone know why my brakes do not work or why the pedal will not come back up?
