Well the ambulance started bucking at the top-end, I figure fuel filter or related (much experince with this and rovers). Well I replaced the Delco filter and fuel bowl seal next to my Rochester, clean the fuel pump bowl and install fresh seal (usual culprit); still getting bubbles coming into the Delco fuel bowl. Next wrap teflon tape around all fittings and double clamp all hoses 180 out; still bubbles. I can't hear any sucking sounds immediately after shut down.
So is there anyway to look for air leaks into a fuel system? Suspects: fuel pump, MOD tap, fittings behind fuel pump.
Jared
Jared
