Water Pump Question
  • crankin
    • Jul 2008
    • 696
    Water Pump Question
    Does anything screw into here?
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
  • KingSlug
    • 177
    Mine has a capillary bulb for my water temp gauge in that location.
    Jared
    Visit The Wandering Hippo (my 109 S2A Ambulance).
    • crankin
      • Jul 2008
      • 696
      Can you cap this off?
      • onecross
        • 85
        yes, you just need the correct size plug for it. rovers north might have it.. if not take the adapter thats in there out and take it to the hardwarestore to match it up.
        or you can put the water temp sender in it so you know how hot its getting..
        good luck
        • 83lee
          • May 2008
          • 36
          I read somewhere that if you take the adapter out, the sump plug for the oil pan will fit. Anybody know?
          • scott
            • 1226
            is that your fuel line running between the head and the water pump?
            '64 Series IIA 88 Canvas Tilt
            '68 Series IIA RHD Ambulance
            '76 Spitfire 1500
            • Terrys
              • May 2007
              • 1382
              Whether you have a capillary tube temp gauge or an electric one, that's where the sender should be installed, so Are you not using any water temp gauge?
              • crankin
                • Jul 2008
                • 696
                scott, its the line that rusn to the carb...
                Terrys, I am not sure if i will use the temp guage yet.
                • scott
                  • 1226
                  crank
                  i'd consider running your fuel line over the top. you can anchor it to the forward valve cover bolt. it seems it would be subject to a bit of heat running as you have it.
                  '76 Spitfire 1500
