here is a link to some info about our ambulance.
Our ambulance
is that a radar detector i see in there?!
really nice truck tho, i'm jealous!sigpic
'91 RRC, SWB (tuned up quite nicely, new water pump, needs radiator repaired or replaced and brakes!) Sold😔
'74 S III, diesel, 109, rhd, hard top
(patiently awaiting cummings 4bt, nv 4500, and np200!)
Finally IN PROGRESS!!
Sold😖 -
Jim What springs are you using? standard mod 3/4 ton ones or 1 tons?Comment
Jim- just count the leaves.Comment
HD apparently. Cool- good to know.
Jim- your ambulance is set up on the MOD chassis with the extended spring hangers right?
RN shuld be able to get you the extra hd springs or you could get some custom made ones from Alcan- they quoted me ~$250 a spring for the rear.
I wonder what the GVW for the ambulance is vs its curb weight? I don't have those specs at hand but other ambnulance owners have indicated that they thought they were somewhat undersprung. Almost as though the vehicle was near max load capacity with the body alone.Comment
according to the info there you are probably exceeding the springs intended max weight 6085 but not by a lot. One ton springs would allow you to be ~ 6750.
Give Alcan a call and see if you can get a set of rears from them. IF I keep leaf springs I'll probably get a set from them too- but our ambulance project is still a ways off.Comment
You choose springs by axle weight, not vehicle weight. Vehicle weight tells you nothing about how the weight is distributed and how much each spring pair is expected to handle.http://www.expeditionlandrover.info/springs.htm
First thing you need to do is fully load the truck for traveling, top off fluids & head down to the scales to get axle weights. Individual wheel weights don't count unless the difference is in the order of 150 lbs of greater. Then handed springs come into play.
I am aware of that and thats great but it is difficult to do when you are building the vehicle from scratch and trying to get somewhere near right to begin with.Comment
weight distribution
Pretty much I try to have eveything heavy as far forward as possible, and at least amidships. Forward of the rear axle so some of the weight is taken on the front end. Works for us. Jim1968 battlefield ambulance/camper
1963 Unimog Radio box
1995 LWB RRComment
