What's going on inside of the Superwinch free wheel hub? Apparently I need to remove all the little hex head bolts to get at whatever's keeping the whole fixture from releasing from the wheel (axle?). The big bummer is some of the hex head bolts are stripped... I got the six larger mounting bolts loose, but the hub is definitely blocked from coming off by something internally.
I'm replacing the Superwinch hubs with some Warn M-11. The Warns look dead simple, but because I don't have mounting instructions I need to ask for some advice on these too.
The green bible has a diagram of the stock hub and it shows a castle nut and cotter pin at the tip of the axle and I'd bet this is what's keeping the Superwinch hubs from coming off. Is this the case and is it something that gets carried over for use with the Warn hubs as well, or is their use specific to just the stock application?
