weird spak plug test results
  • 73series88
    • Oct 2009
    • 587
    hi
    i had the series 3 88 a few weeks ago that would only runand low speeds and sputer and die
    truck wont start at all now
    no issues with the fuel system
    opened the distributer and replaced the condenser and the high tesnion lead
    cleaned the ground lead
    new plugs wires cap rotor everythings changes
    pulled the coil out of my 912 because i know its good no change
    was doing a spark check with the plugs
    great arch if i hold the plugs away from the ground alittle
    now touch the plugs to the ground and i get nothing on the ignition gap
    iif i touch the plug to the ground i should still get an arch on the gap shouldnt i ?
    any ideas
    thanks
    aaron
    67 series 2a 88 RHD sold
    88 RRC sold
    60 mga coupe
  • greasyhandsagain
    • Oct 2009
    • 155
    Is the low tension lead and the condenser lead ON TOP of the point frame? They need to be in contact metal to metal with the points, and NOT with the little plastic washer inbetween.
    Hows your compression?
    Reason I ask about these two things is that Ive just went through similar problems...and these were the answers.
    • 73series88
      • Oct 2009
      • 587
      yeh the wires are in the right place
      a friend told me to take one of the 912 plugs and test it with that
      arched perfectly
      he said the plugs must be shorting out
      remember this is the truck that wouldnt restart until it cooled down
      now there just shot
      autolight 403
      gonna run out and get the right ones
      88 RRC sold
      60 mga coupe
