Mt Mansfield Heater, or Kodiak MkIII
  • stomper
    • Apr 2007
    • 889
    My 66 rover currently has a kodiak MkIII heater installed in it, but it only blows luke warm air. I have also noticed an occasional antifreeze drip from the rear of the passenger side wheel well. My question is this: Should this heater produce good heat output if I have the core rebuilt, or should I just invest in a Mt. Mansfield heater? The cost of the Mansfield is more than I really want to spend. Also, I do not have the air intake on the right side wing on my truck. Can the Mansfield heater be set up to accept the heater duct set-up on the front of the radiator panel, or will I need to cut the hole in the wing?
    If I stay with the Kodiak, are new cores available, or will another type of core fit? There aren't many radiator shops around here that I can find to rebuild the original, but I am willing to travel.
  • Bertha
    • Nov 2007
    • 384
    I have had both in my truck and can honestly say the Kodiak and the Mansfield are about the same heat output. I had the Kodiak heater core replaced a few years back with little issue by a local radiator repair shop.
    1971 88 (restored and as new)
    1967 88 (the next project)
    • yorker
      • 1635
      Rebuild the Kodiak, they are simple, you already have it installed etc.
      Land Rover UK Forums
      • greenmeanie
        • 1358
        As a matter of interest how does the late IIA/SIII heater compare with the Kodiak and Mnt. Mansfield? I am talking about the heater that has the core box semi recessed into the top of the footsell on the bulkhead and the large duct runnign along the base of the dash.
        Not that i need a heater. It still T-shirt weather here.
        • Bertha
          • Nov 2007
          • 384
          Kodiak has better output, however a lot depends on the truck configuration you have ie: soft top/hardtop/88/109 2door or 5 door/interior trim or no interior trim.
          In my late 2a 88 with a hardtop and full interior trim(headliner door panels etc) its standard heater works quite well, even on cold days, however my 109 3 door with hard top and no interior trim, is tough to get warm even with the MT Mansfield heater installed.
          I am currently working on a way to adapt a Heatercraft heater to a series truck and get it to look somewhat factory. They sell 28,000 to 40,000 btu units which should be able to heat even the most cavernous of trucks.
          • Mercedesrover
            • 343
            Get a new $20 heater core from NAPA and make sure the motor is spinning as it should. Both my Rovers have original heaters with new heater cores and both will heat you right out of them.
            www.seriestrek.com
            • TeriAnn
              • 1087
              The Kodiak is rated at 17,500 B.T.U/hour with the motor blowing 190 CFM. I think the Mansfield is a little higher but no a whole lot. The RN site probably has the rating.
              Cores get clogged over time. It never hurts to have a radiator shop boil one out and they usually can solder any leak. And remember the heater depends upon a hot thermostat to produce heat.
              I have the input of mine set up to be wither recirculating or a combination recirculating & fresh air. It gets real toasty recirculating but it can get humid as well.
              Teriann Wakeman_________
              Flagstaff, AZ.
              My Land Rover web site
              • greenmeanie
                • 1358
                To my original hijack question do you know what the stock OEM late unit was rated at? I agree that due to age most now have a depleted performance but I've an academic interest to compare performance numbers. As Jim points out and you provide some reasoning behind I'd rather expect the stock unit to have similar performance.
                I can see the upgrade for earlier trucks but I'm wondering if a Kodiak/Mansfield is much of an upgrade for a 69+ truck?
                • Mercedesrover
                  • 343
                  I say no. The original Smiths unit is great. Put a new heater core in it, ( Really, they're $20 brand new from any parts store ) clean out the mouse nests and it will do just fine.
                  www.seriestrek.com
                  • derekchace
                    • May 2008
                    • 463
                    a new core for the heater from the parts store is probably not an option on my 24v rover?
                    GMR Imports
                    802-655-4874
                    802-324-3370
                    gmr4x4.com
                    • Mercedesrover
                      • 343
                      Voltage doesn't have anything to do with it. The "core" is the radiator inside the heater box. Over the years they get plugged up both inside and outside and don't transfer heat very well.
                      If you're having trouble, take your old core out and bring it to the parts store. Even if it's different than the Smiths style I'm sure they can match it up with something for very short money.
                      By the way, the replacement core part numbers for the Smiths style heater are as follows:
                      4-Seasons/GDI - 399024
                      Everco - H2329
                      Napa - 660-3076
                      www.seriestrek.com
                      • stomper
                        • Apr 2007
                        • 889
                        Just to clarify the vehicle type, It is a 1966 88" tropical hardtop. It has an original looking headliner, but I doubt there is much insulation above it. The doors have the deluxe interior panels, etc. When I place my hand over the output duct to the heater, it is luke warm in temperature. The blower output is fine. If I leave the blower off for about 5 minutes, and then turn it back on, it blows quite warm for a few minutes, then cools off again.
                        All of you have given me a bunch of great info. I think it is worth keeping the Kodiak then, and get it operating correctly. Does anyone know of the correct replacement part number for a new core at napa? I would just as well replace the whole core with a new on rather than have the rover sitting in pieces while I get the current core rebuilt.
                        Now my next question: What is the easiest way to get the old core out? I just bought this rover in August, so I haven't had a lot of time to take things apart yet. Do I need to remove the passenger side wing? Since I can't seem to even see or reach the coolant hoses attachment points, I assume this is the best course of action.
                        Also, I have the original looking coolant flow valve attached to the top front of the engine. I have noticed some of you have it mounted to the bulkhead instead. Are these valves notorious for breaking, or restricting coolant flow to the heater? I can pull the valve open or shut, but the heat output doesn't seem to change much if any.
                        • TeriAnn
                          • 1087
                          Everco - H2329
                          Napa - 660-3076
                          Which Smiths heater? The round core one? The flat core one that mounts inside the bulkhead above the gearbox? The Series III fresh air heater?
                          I'd like to capture these numbers for my alternate parts web page but need to know which Smiths heater.
                          Thanks
                          Flagstaff, AZ.
                          • derekchace
                            • May 2008
                            • 463
                            I would love to know how to remove the core on the flat military style mounted above the gearbox
                            GMR Imports
                            802-655-4874
                            802-324-3370
                            gmr4x4.com
                            • yorker
                              • 1635
                              Thanks
                              IIRC Jim has the fresh air heater- the one with the core mounted inside the engine compartment- it was used on some IIAs too I think- I am pretty sure the late IIA one is the same as the series III though the distribution inside is different? Someone should probably compile some pics inside the engine compartment and out.
