To use or not
  • Pete
    • 93
    To use or not
    When reasembling items do you use: gasket, gasket and rtv sealent, or just rtv sealent (gasket maker)?
    Pete
  • kevkon
    • Aug 2009
    • 364
    That really depends on what the nature of the two mating surfaces in question are and their condition, what the gasket is made of and it's "crush" , and whether the seal is to be permanent. There are other choices besides RTV silicone, as well.
    Bottom line is that RTV silicone is a great product but it should only be used in the proper situations and very judiciously. Too many times I find this stuff where it absolutely doesn't belong.
    94 D-90 tdi
    72 Series III
    • kevin-ct
      • 309
      More RTV is not better...Less is more.
      Kevin
      04 XJ8
      92 RRC
      02 Benz E320
      95 RRC (sold 5/10)
      72 Series 3 (sold 4/10)
      70 Series 2A (sold 6/10)
      Morgan +8 (sold 8/09)
      90 Jetta (308k miles) (sold 5/11)
      72 Triumph Stag (sold 1/08
      • thixon
        • 909
        personally, I'm much bigger fan of hylomar (blue non setting to be exact), rather than rtv. Worth the money IMO.
        Travis
        '66 IIa 88
          If there is a paper gasket made for the part, I'll use it along with non-hardening gasket sealant (not RTV).
          • rwollschlager
            • Sep 2007
            • 583
            Pete
            x2 on the hylomar. It was recommended to me by Les and others at this years All Metal Dash Rally. It never fully hardens. Apply a light smear to both sides of the paper gasket and wipe off excess. I've heard if done correctly, you should be able to re-use your gaskets after they've been hylomar'ed (riverport rovers).
            I've heard the RTV for Ford has similar properties.
            -Rob
            72 SIII 88
            67 SIIA 109
            82 SIII Stage 1 V8
