Okay, before I go ballistic on our hosts Monday morning help me out a bit if you would. First, I need to calm down, second I need to end up with the right part. Helping me with obtaining the right part would be most helpful, I may sip on a scotch for it's soothing effects.
I 2nd day aired a rear brake line (594747) for my dual system 109. So, this weekend's goal was to actually drive the old girl. I have been looking forward to this for too long. Anyway, I start at the front unrolling and shaping the line as I go to match the one I removed. About half way toward the back as I am trying to straighten out the whole new line I notice it is quite a bit shorter than the old one. Turns out it is about 16" shorter than the old one and 4" shorter that the straight distance between the front 4way junction and the rear bracket for the flex line.
Old line: about 88",
New line: about 72"
straight line distance between end points: about 76"
I have a dual system with a 4 way junction. Two lines and the switch entering on the top from the master cylinder and dash, respectively; two lines exiting the bottom, one to the front brakes, one to the rears. The junction is mounted at the tab I have on both the SIIa and SIII chassis and the rear bracket is also in the same location on both chassis.
So, is there anyone with a 109" that could use a 72" rear brake line, or did RN send me a bad part?
New line: about 72"
