I just recieved one of the replacement sender units for a rear mounted tank in my 5 door and wanted to check to make sure that I am doing it right before installing it
I connected the two pieces - the one with the float and the upper piece that mounts to the tank - with the two small c clips that were included but seems like they can slide quite a bit
1. Should I bend the ends of each of the rods so the c clips can not slide off?
2. How do I calibrate / adjust it so that F=full and E=empty
