Galvanized chassis, Marsland vs Richards?
  • Mountain132
    • 79
    What seems to be the major difference between the 2, any preferance?
  • Leslie
    • 613
    If I'm correct, Marsland acquired Land Rover's frame jigs and make a perfect SIII chassis, available galvanized or not.
    Richards works in lower numbers, and builds specific chassis; if you want a SIIa chassis instead of a SIII chassis (minor differences, they are exchangeable w/ each other but there are some details that vary), then you can get a SIIa-specific one from Richards, but not from Marsland.
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    • zayante
      • 59
      Availability from US suppliers is probably a lot of it, unless you are paying to have a single frame shipped over.
      Richards reportedly taps/chases the holes. They list both 88 and 109 chassis, including 1 ton and 6 cylinder variations. There's a removable transmission cross-member option.
      I was surprised that Marsland doesn't list the 109 chassis on their web site, just the 88 and LW 88 Airportable.
      I've always been interested in a 109 coiler conversion. I don't know whether either company would build one as a special order. I read somewhere that Richards would.
      Chris
      1965 IIA 109 SW
      Nolite id cogere, cape malleum majorem
      • Leslie
        • 613
        Allow me to amend that; it appears as though Marsland does also have a SII/SIIa chassis, but I've yet to see such offered stateside, I've only seen SIII Marslands...
        -L
        '72 SIII SW 88"
        '60 SII 88" RHD
        • Leslie
          • 613
          Designa is the only one I know of that does a Series-coiler conversion chassis.
          -L
          '72 SIII SW 88"
          '60 SII 88" RHD
          • HybridIIA
            • 100
            Here you go: http://louisville.craigslist.org/pts/1534490054.html. I built my truck on a similar foundation and am very happy with it.
            '62 109 - coil sprung
            '64 88 - coil sprung
            • zayante
              • 59
              Thanks, Mogly406 and Leslie.
              Chris
              1965 IIA 109 SW
              • TedW
                • 887
                So.......Is there any quality difference?
                It appears that our illustrious hosts sell both.
                • My wife said no landy!
                  • Feb 2011
                  • 12
                  Being new here, I'll have a lot of questions...so might as well start with the frame...what about serial numbers??? Do people stamp new numbers on their frames?
                  I am looking for a late 50s to early 60s II or I to slowly restore, and so far most have bad frames. Would a replacement frame be a perfect replacement...or should i keep looking till I find one with a good frame?
                  • Terrys
                    • May 2007
                    • 1382
                    I saw a Richards at DAP one day last year and was impressed with it's quality. I've done 2 using Marsland and there were moments of frustration.
                    Marsland builds theirs using two sections, welded on the CL, top and bottom, sort of like this: []
                    Richards builds theirs as Land Rover did, using 4 seperate flat plates, welded at the corners.
                    When and if I can dig the '69 PU out from under the rubble, my son is going to use a Richards.
                    • jac04
                      • 1884
                      ^^Terry, my Marsland was welded in the corners and not like []. Interesting.
                        • Feb 2011
                        • 12
                        Thanks!
                        What about the vin numbers? Did you use a hammer to punch your old frame's numbers on the new frame...or would Richards do this with the correct font/number punch?
                        Edit: I just checked out the Richards site, and it seems they make two different chassis...A production Chassis, and a Replica Chassis; http://www.richardschassis.co.uk/ser...series-ii.html ...probably why you both saw different chassis...
                        • TedW
                          • 887
                          I've read (and heard) similar comments about Marslands from various sources - and lots of positive comments, too.
                          I've heard good (but no bad) comments about Richards chassis; that could just be because Marslands might have been sold in the US longer so there are more of them around to critique.
                          Has anyone had any problems with their Richards chassis?
                          Any other comments on Richards, pro or con?
                          • martindktm
                            • Jun 2008
                            • 218
                            Mine is a MarsLand and so far im very happy and have no concern yet. And it is also built in 4 sections like the original one.
                            • jac04
                              • 1884
                              I suppose you could do this, but I'm not sure about the legality of re-stamping a VIN. With my Lightweight, I just cut out the right front section of the frame that had the VIN stamped in it (along with enough material to prove that it's a Lightweight chassis). I cleaned it, used rust converter on it, then packed it away.
