I have been working and replacing my front LR pads, etc. I have also bleed the brakes for air. My brake pedal, on the 1st press, goes all the way to the floor, a second press on the brake holds and I have brakes.(This before and after pad/lining change). Calling around local brake companies state it sounds like the master cylinder or air in the lines. Any ideas? Again, no brakes 1st time and goes all the way to the floor? I need a fix so I can use, as it is no good at the moment.
Thanks, Regan
Thanks, Regan
