I've got a bit of an electrical leak, so I picked up one of those battery cut-off switches that is just a knob on a terminal connector. I've got all the hardware I need to attach it except I failed to notice that the terminal connector on the negative cable is permanently attached (the positive one is not) to the braided cable. I can cut the braided cable and crimp on a copper lug (a lug would be best to attach to the cut-off connector), but the braided cable is looking fairly rough so should I just be replacing it?
If I can & should replace it, can I use a standard black battery cable or is it best to replace with braided? Braided would certainly be more 'stock' (assuming this is the original cable, which it appears to be), so where can I find a replacement as I didn't find anything from our hosts?
It appears that the negative batter cable is just attached to the bottom of the battery box, correct? How hard is it to pull the whole battery box out? The only thing else that appears to be attached to it is the oil bath filter. The battery box is fairly rusted, so it could really use a sanding & coat of POR-15 before putting it back if I do take it out.
