Can you galvanize a differential? And I mean after you remove all the innerds... or are the clearances perfect?
Galvanization Question
By differential, do you mean axle housing or the actual third member?
I've often thought about galvanizing an empty axle housing, as there would be limited clean up after galv required, mostly to protect the rust haven axle reinforcements.
The third member would require much too much work to clean up after galv and being cast, isn't a rust issue really, other than cosmetic.
I use POR-15 and it's held up very well.
Cheers
PeterComment
I know I have seen galvanized axle cases in the U.K.. If you are talking about the actual differential case, I do not see any advantage to galvanizing that as I have never seen or heard of them rotting. The diff pan and the long side reinforcement channel is the only rust problems I have seen, they are both east repairs though.1973 NADA 88Comment
I've thought about it.
To solve the mounting flange problem, I think you could bolt up sacrificial rings to the three flanged surfaces. Distortion would be another problem, but I doubt it would be bad. I would think that such distortion could be resolved at home with the right measuring tools, or by a shop used to such jobs. Like most things, it just depends on how badly you want it.Comment
