series III lights
  • Mountain132
    • 79
    #16
    4 inch amber lense replacement
    More alternate parts. A fairly decent replacement for the Lucas four-inch amber lens is a replacement lens by Grote, which can be found at Central Tractor for about $2.79. It is their part number 55573. The Grote lens is not drilled, but that can be remedied by drilling, and you will need to grind a little flat place for the machine screw head. It was a bit shallower than the one from the Prince of Darkness, so you'll need to get shorter machine screws. If you get flathead screws, you can countersink the front of the lens where the screw head seats.
    Reprinted from the OVLR Newsletter, October 1997
    Has anyone used these?
    • yank
      • Nov 2007
      • 191
      #17
      I don't think the grote lights sit flush with the body.
      72 SIII
      • Tsmith
        • Jun 2009
        • 103
        #18
        Moss Motors has a MG Midget sidelight that is similar. I think the SIII lights were flat and the drawing here shows an angled cross section:
        The same lights were used on by Morgan. They show a photo of them in the catalogue of some of the Morgan parts suppliers...that doesn't mean that they HAVE them.
        Tom Smith
        SII
        Tom Smith
        '60 88" driver
        '53 80" project
        '60 Morgan drver
        '60 Morgan project
        33 Farmall F12
        • amcordo
          • Jun 2009
          • 740
          #19
          They do not sit flush. These are the two I'm sending you Phill. See the pic - you must have a hole in the body for the plug the lamp fits into, but the rest of the light's housing sits outside the body with two screw holes. If anyone gets these I would STRONGLY suggest sealing the metal portions with a clear epoxy and greasing up the plug that you put the lamp into with a good amount of vaseline. They tend to rust (what doesn't) fast and in a few seasons you will never get a burned-out lamp out of the socket without planning ahead.
          • siii8873
            • 1013
            #20
            side lights
            I need one of the chrome pieces to complete my set. If anyone has one I'd be interested
            THING 1 - 1973 88 SIII - SOLD
            THING 5 - 1958 109 PU
            THING 6 - 1954 86" HT
            • yank
              • Nov 2007
              • 191
              #21
              Thats what I was looking for. Thanks again
              Aaron I will probably have an extra trim I can give you.
              72 SIII
              • siii8873
                • 1013
                #22
                I need one of the chrome pieces for my side lights if anyone has one.
