Today i was going to remove the rusted front exhaust pipe from my IIA and after days of soaking the nuts with PB blaster i still managed to break 2 of the 3 bolts off. I guess the good news is there are about an inch of the studs still sticking out of the manifold. Am I in big trouble? are the studs reverse threaded in? any help would be great! thanks
Broken studs on exhaust manifold..
1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSETags: None -
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
Probably not
They shouldn't be reverse threaded. Was the one you managed to get off without breaking reverse threaded? Just asking because if it's not then the others shouldn't be either, not that I think they are reverse threaded anyway.
RegardsWalker
1968 Series IIA-"Ronnie"
88" SW, 2.25L Petrol, LHDComment
the nut i got off was regular thread. I just got the nut off though, the stud stayed in like im assuming it was supposed to so thats why i was thinking the studs are reverse threaded into the manifold or it would have come out as well. I knew id need a torch someday working on this rover so now may be the time.1970 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
They're standard exhaust studs, no reverse threads. I was able to remove mine just by putting two nuts on the end and wrenching the whole thing out, but I think I got lucky they weren't so fused in place...'67 109 NADA #413 - rebuilding w/ TDI & galvy chassis.Comment
Thanks for the info. Ill try using the 2 nuts that i broke off and see if that works. Im thinking ill need some heat to help though...1970 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
you are lucky that there is still some meat to grab onto. The last two that snapped on me were flush with the surface. First, I tried to weld a nut onto the stud and try and back the remaining piece out, but to no prevail, weld wouldnt stick. I ended up drilling and heli-coiling a new thread in there. Snapped studs are always a bummer because the tend to turn a half hour project into an all day affair.
-Rob------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
well i tried using a snap on stud puller. first broken stud came out like a charm. I was pumped but the next broken one broke even more! and is now flush with the manifold so thats now tomorrows project. The one stud that didnt break in the first place ended up snapping anyway when i tried to remove it to replace with a new one... the rover didnt like that. Oh well, nothings ever easy or even close to easy on this rig so far.1970 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
Masonator,
Do you have a torch? Everyone's advice about the smoke wrench is spot on. If its stuck that bad, you'll likely end up breaking the end off an extractor if you go that route, without heat.
If you don't have a torch set up, now's your opportunity to invest in one
Instead of an extractor, you can try to weld a bolt to the end of the stud, but again, I'd still heat that sucker up, independently of the heat from the welder.
Good luck! We've all been trough it.Travis
'66 IIa 88Comment
Prevention???
My new exhaust system arrived on the UPS truck today - so that's a job I'll be tackling in the next couple of weeks. I fully expect to face some level of nightmare getting the old studs out of the manifold when I do.
Since I am putting in shiny new ones, is there some way to prevent or at least slow down the way they corrode themselves into one-ness with the manifold? I've never really understood why these seem so much worse about it than any other random steel fasteners anway.
Maybe a different material for the studs? I was also thinking about hi-temp stove paint to try and protect the exposed length at least.'72 88" - daily driver
'64 109 SW - project in waitingComment
Anti-seize.
Don't worry about the composition, whether is it aluminum or copper, just use something! Liberal distribution is the key.
Old skool cars often used brass for manifold nuts and the dissimilar metals prevented fusing. I prefer grade 8 nuts on installs, not for the torque aspect, but because they are markedly stronger (read as harder) years down the road compared to grade 5 or worse yet, grade 3 stuff found locally.64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
[QUOTE=rbonnett;50351]
QUOTE]
Your problem is carbon steel mixed with cast iron plus heat = corrosion. When I overhauled my manifold years ago I drilled and installed helicoils.With high temp anti sieze on install I've never had a problem since.Comment
