Looking For Projects
  • G.G. Sprock
    • Aug 2008
    • 47
    #16
    I will try to make time to get after the spring bushing tool this week. I like the concept of fitting it to an air-chisel.
    As far as the gear box mainshaft tool, what nut are you trying to get? Is it the castle nut when you are adding a PTO or overdrive? If so, I already have made up one of those and will just have to find the drawings... somewhere, lol.
    • BackInA88
      • 332
      #17
      Hey that's the one!
      Steve
      71 IIa 88
      01 D2
      • G.G. Sprock
        • Aug 2008
        • 47
        #18
        Okay, I will go scrounging through my stuff tomorrow. Think I already have a part profile for modifying an existing 1/2" drive deep-well socket... that is how I recall I tackled the problem.
        • straightcut
          • Feb 2010
          • 2
          #19
          Right. Most people start with a 1/2" drive deep socket. Sounds like you just need to put what you have made into production. I'd be all over one of those!
          Mark
          • ignotus
            • Sep 2009
            • 237
            #20
            bushing tool
            GG,
            I don't think an air chisel would work well. I would like something that fit around the frame and pushed the bushing out/in with a bottle jack.
            I would however purchase a couple of the items shown by airsafeone. Those I could use as described with a bottlejack....just fab up a holder out of some C channel.
            gene
            1960 "bitsa" 88--Ignotus
            1960 109, 200TDI
              #21
              That flange I originally posted is part of a system that uses a threaded rod to pull the bushing out.
              In my mind, the full system looks something like this (shows 2 systems, one front view and one rear view):
              • yorker
                • 1635
                #22
                Originally posted by BackInA88
                How about making up some gear box main shaft tools?
                It would be a good project as it would be lathe and mill work.
                Steve
                £60.00...
                Land Rover UK Forums
