Hi all!
So with the two speed (+ off) wipers.... Does a different voltage come from the switch itself when you select the variable speeds, or does the switch just chose a different wire path into the wiper itself? To be more specific, I'd like to relay the wipers if possible. If the switch is just chosing a wire path then I can use two relays to do this. If the switch is what is altering the power supply then it cannot be done easily. Anyone have an answer so I don't need to open the dash in 30 degree wx? Thanks!
