On top of the transmission housing right in front of the shift lever is a plate with model and serial numbers. I thought it was because it had been covered in oil for 40 years that it was so clean but when i decided to read it today i noticed it said land rover genuine parts...range rover? I have a 1970 ex mod 109. Does this mean it has been replaced at some point in its life? I'm pretty sure range rovers were not even a thought in 1970.
serial number plate on transmission says range rover?
1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSETags: None -
Quite possibly...
YVB 151H was the very first 1970 production Range Rover.
http://www.peterstoys.com/range-rover-no1.htm
The range rover should have had the Lt95 and not the series transmission, if I'm not mistaken. So possibly yours has a special stamp or cast uncommonly seen due to rarity or the amount of oil covering up all the others.On top of the transmission housing right in front of the shift lever is a plate with model and serial numbers. I thought it was because it had been covered in oil for 40 years that it was so clean but when i decided to read it today i noticed it said land rover genuine parts...range rover? I have a 1970 ex mod 109. Does this mean it has been replaced at some point in its life? I'm pretty sure range rovers were not even a thought in 1970.
-Rob------------------------------------------------
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
As noted by Thompson, the Range Rover first hit the dealerships in 1970. A "road rover" had been under consideration, design, and planning since the late 1950's.
JeffJeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
