I know the product has been around since 1980 and I have read reviews on it. Has anyone here used this product on a Series Frame or Bulkhead?
My 1972 Series III frame is in pretty great shape with only some surface rust that I plan to scrape off before I paint or use POR 15. I know that frames can and usually rust from the inside out, thats why its best to have them galvinize dipped.
I'm not doing a frame off restoration, I only have the front floor/seat base removed while I have the transmission/t-case/over drive out for new seals and a new clutch/PP to install. This would be a good time to treat the center section of my frame/cross member. They sell POR 15 in small 4oz. or 16 oz. cans so you can do sections of your frame and not let an entire gallon go to waste before you get to the other half of the frame weeks later
Must be topcoated if it sees the sun. Frame probably okay except in fender wells. front and rear exposed rails.
