So, do the turn signals on the front wing have to be amber? Mine at the moment are a hodge-podge of Defender and SIII bits and are all broken and barely working... I want to replace the whole signal on each side, and our hosts have a full kit for each side - but they only have clear lenses on them (these ones). Is that still okay to use?
Turn signal lens colour?
I've only seen amber lights for original turn signals. If you are set on those lights, then why not just put an amber bulb in them?
Otherwise, I suggest getting the Euro Defender light kit:
What about this kit from our hosts?
http://www.roversnorth.com/store/p-17090-lamp-kit-euro-style-series-and-defender.aspx
I know it's not for rivet counters, but it may be worth considering?1982 SIII 109 RHD petrol project.Comment
In Europe this is what is factory fitted and the original looking set, from the Series II to the Series III models. (some models had glas lenses though)What about this kit from our hosts?
I know it's not for rivet counters, but it may be worth considering?Comment
Similar question on rear turn signal lenses - my '65 has two red lenses on each side and I always thought that was how it came but most pics I have seen since show these with amber lenses for the turn signals. My truck was basically a barn find which sat for a few decades before I got it, but that doesn't mean the original owner didn't change them at some point.
At any rate, one of the lenses needs to be replaced so if it should have amber ones I will buy 2 of those.
It is an original US truck, not a recent import, if that makes a difference.
The fronts are both clear.1965 Series 2A 109 pickup dieselComment
Thanks, I believe that is correct and the pics I was looking at were of later IIAs. Ike's post above was the clue - early IIAs have both clear lenses up front and both red lenses on rear.
Now I just need to find the rubber bits for the front ones ...1965 Series 2A 109 pickup dieselComment
The front on mine has clear on top, amber on the bottom (bottoms are turn signals). The rear has amber on top, and red on the bottom (tops are turn signals). This is an '76 SIII 109 from England.
'95 R.R.C. Lwb
'76 Series III Hybrid 109
'70 Rover 3500SComment
Series 2A up until they got strangled by the US DOT used Lucas L488 single filament clear marker and L594 single filament clear turn signal with amber bulb. Both the L488 and the L594 glass lenses are available (reproduction) from several vendors. You can buy reproduction complete lamp assemblies or component parts including the metal bulb holder, the rubber boot, the lenses, and the chrome ring.
In the rear there were the Lucas L691 and 692 the L691 is generally amber as it is single filament used for turn, and the L692 is usually red for stop and tail as it is dual filament. You can still get them as they were used on gazillions of Britcars from the sixties...Lotus, AC, and many more.
Hope that helps.Comment
