Im in the process of rebuilding my 109 ex mod and in several places i need to touch up the undercoating on the frame and some other spots. Is there a product out there (waxoil?) that would blend into the original stuff as far as texture and hardness? Thanks
Military undercoating
1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSETags: None -
The original MOD undercoating was good but has several drawbacks that appear with age. It does get stiff and brittle and therefore cracks. Water can then penetrate and is now trapped against the metal of your chassis. It is also a pigs arse to remove.
Waxoyl works well enough but on my 101 I mixed engien oil (New cheap stuff) with turps IIRC and brushed that on as it penetrates a bit better. CLeanthe chassis afterwards and then top coat with the black hardwax.Comment
