it's obvious
No one has said satphone yet. I live outside the U.S. and it is one of the first things I purchased when I moved. Comes in handy in central Florida as well. Some areas in those swamps are time warped but satphone always gets back to civilization.
All the tools that recommended sound good to me. I carry a Bluepoint set of sockets in my truck ($89.00 bucks for a premium set of sockets isn't bad)
Emergency tools are great to have but preventative maintenance will go a long way to keep from crawling under the truck. Make yourself up a log book for when you change out parts. track when the points need to be changed and other periodic maintenance needs. If you are planning a trip and project the you will need to change something in route then change it before you go.
We have a saying in this house "El Land Rover nunca perdone" "The land Rover never forgives" In other words if the truck is starting to make noises that are unusual or it is not handling right in some way from normal then get it worked on immediately. You can keep your enjoyment level higher that way.
The tools recommended before this post sound pretty good but there is always the widget you need that you do not have. Then "SATPHONE"!
