ran outa gas the other day., new tank, new pump, took carb apart, no rust in any jets or fuel bowl area. ,my 1961 109 only runs with choke on after running outa gas. what could cause this, has no power, but will idle fine. no rust in tank, carb, or sediment bowl.choke has to be on fully to run good.
truck only runs with choke on????
Tags: None
64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucks -
1991 Range Rover HunterComment
filter
I just got done with the same thing, blew out all fuel lines, cleaned bowl, pulled the pickup tube and the screen was shot.
I put on a wix 33052 on the end of it with a little persuasion and its running good.
73 SIII swb 139 CI, rochester carb
working on:
rear bumper, window glazing, roll cage, paint top, etc... etc... etc....
http://jims73rover.blogspot.com/Comment
i did fix it today, its the original solex. there was a passageway with lots o rust in it, i think it was it with the 55 jet.blew it out and used carb cleaner. when i bought the new tank, i did put a new pick up tube and sock on it. the rust must have been from yrs ago.Comment
